Adding a data source
Usage limits apply and are determined by your plan.
Data sources are how you connect SquaredUp to the tools and services your organization relies on, such as Azure, GitHub, AWS, SQL databases, or even simple CSV files. Once connected, SquaredUp can index, explore, and visualize the data from these sources through dashboards, data streams, and objects.
This article introduces how data sources work in SquaredUp, how to add your first instance, and highlights the next steps on your journey to achieving operational intelligence.
See Plugins and data sources for a deeper look, as well as help with troubleshooting.
What is a Data Source?
A data source is any external system you connect to SquaredUp. SquaredUp has an extensive list of available data sources which can be viewed here.
If you don't see the data source you want, you can suggest a new data source!
Add your first data source
You can add a data source in just a few main steps. The exact configuration involved depends on the plugin settings, but the process is always similar.
- Navigate to the workspace you want to add the data source to. From your workspace, click Add data source in the left-hand menu.
- Search for the service you want to connect, for example Sample Data.
- Select the plugin to open its configuration page.
- Configure the plugin as required. In this case, simply enter a Display Name to identify it (e.g.
Contoso Sample Data). - Click Test and add. SquaredUp tests the configuration, and then the indexing window displays and the plugin uses the provided configuration details to create a connection to the data source.
- Once completed successfully the following message displays. Click Continue to complete the process.
Congratulations, 🎉 you added your first data source!
Once a data source is added, you'll notice that it automatically appears under the Data Sources section of the navigation pane, under which you’ll also see a curated set of pre-built dashboards and perspectives that were installed with the plugin.
Sample Data creates Contoso, a fictional software company with services, hosts, release pipelines and customers. About two and a half hours ago, a release to its Payments API caused an incident. The incident moves with the clock, so whenever you add the plugin, it has just happened.
All of the data is generated. The plugin never connects to your systems.
Next Steps
Now that you've added a data source to your workspace, you're ready to take the next step towards operational intelligence and start uncovering valuable insights within your data!
Build dashboards
When you feel ready, you can jump in and start building your own dashboards and discovering new insights.
You can do this by copying and making tweaks to the pre-built dashboards installed with the data source (select Copy dashboard), or by creating an entirely new dashboard from scratch.
See Building a dashboard to continue the tutorial.
Pre-built dashboards
If you're after inspiration for what's possible with your shiny new data source, one of the easiest ways to get started is by diving into the pre-built dashboards and perspectives installed with the plugin. These can be accessed from both the navigation pane and the overview page.
Each data source has a bespoke set of pre-built dashboards and perspectives, designed to help you quickly understand trends, spot anomalies, and make data-driven decisions right out of the box.
For Sample Data, start with Executive Overview. Payments API is red, two other services are amber, and three customers are breaching their SLAs. The other dashboards show the same incident from different angles:
- Service Health: Every service and host, and where latency spiked.
- SLOs & Error Budgets: How much error budget the incident has used.
- DevOps & DORA: The release that caused it, counted as a change failure.
- Service Desk and Customers & SLAs: The P1 tickets it caused, and the customers missing their SLA.
- Business Metrics: Orders dipping while payments fail.
- Cloud Cost: A separate problem. Search Service is over budget.
