SQL Analytics
SQL Analytics allows you to carry out advanced manipulation of data using a SQL query before you visualize it.
The analytics editor provides full-featured SQL support and is powered by DuckDB—an in-process database management system designed for efficient analytical query processing.
The beta version of SQL Analytics previously used AlaSQL. While you can still copy the tiles created using the beta version, copying an AlaSQL query may not always be possible due to compatibility reasons.
What you can do with SQL Analytics
SQL Analytics lets you transform, aggregate, and combine data before visualizing it. Common use cases include:
- Calculate the average time difference between when a ticket is created and resolved using SQL, then visualize the Mean Time To Resolution (MTTR).
- Query AWS CloudWatch data to find the 95th percentile response time of a microservice, and display it as a Service Level Indicator (SLI).
- Combine entry points from different sources, such as Azure Cost data and Azure Monitor data, to analyze the potential cost savings of turning off unused virtual machines.
Where to access the analytics editor
In the tile editor, there are two ways to access the SQL Analytics editor:
- Select SQL from the Filter | Group | Sort tab to open the SQL editor, where you can use SQL to shape and aggregate the current dataset.
- Enable the Multiple datasets toggle at the top of the screen. This switches from the standard tile editor to the Multiple datasets editor, where you can use SQL to shape and aggregate data from multiple datasets.Note
If you exit out of the SQL Analytics mode, reverting to using the default tile editor for a tile, then you lose your SQL queries and datasets, as only the first dataset is saved.
Use the SQL editor
This uses standard Structured Query Language (SQL) and is powered by DuckDB.
By default, the Query tab in the SQL section of the SQL Analytics Editor contains a query that returns everything from the first dataset. Edit this query to return and manipulate your data as needed.
Select * FROM ticketsIf you perform a Count aggregation on the Shaping tab for a dataset and therefore have a column named "count", you must wrap the column name in `` to reference it in SQL: `count`.
Query editor buttons
Use the following buttons to interact with the Enter your query window.
IntelliSense
The SQL query editor comes packed with IntelliSense, designed to streamline query creation. Each keystroke triggers the assistant and provides:
- Context-aware auto-complete: The editor suggests relevant SQL syntax, table names, and column fields based on your current input, reducing the chance of errors and speeding up query writing.
- Real-time error detection: Common mistakes such as syntax errors or missing keywords are flagged as you type, helping you correct issues early.
Query datasets
How you reference data in your SQL query depends on where you're writing it:
- Filter | Group | Sort > SQL: The query operates on the tile's current dataset, which is always referenced as
dataset. For example:SELECT priority, COUNT(*) AS TicketCount FROM dataset GROUP BY priority ORDER BY TicketCount DESC; - Multiple datasets mode: Each configured dataset is exposed as a table. By default these are named
dataset1,dataset2, and so on (although you can rename them to something more meaningful). For example:SELECT priority, COUNT(*) AS TicketCount FROM dataset1 GROUP BY priority ORDER BY TicketCount DESC;
Both queries return the number of tickets for each priority level. The difference is the dataset name you reference.
In Filter | Group | Sort > SQL, use dataset, which represents the current dataset. In Multiple datasets mode, reference the dataset you want to query (dataset1, dataset2, etc.).
After enabling the Multiple datasets toggle, the tile editor view updates to facilitate the use of multiple datasets. From the left-hand pane, you can add / edit / delete each dataset you want to use, and these display below the visualization alongside the SQL output.
If you had already selected a data stream and objects in the tile editor before enabling the toggle, then it is displayed as dataset1 and the SQL > Query tab immediately opens.
Rename datasets
Datasets can be renamed by clicking the tab of the dataset to enable editing – hit Enter to save the change, hit Escape to cancel. For example, if you are looking at Zendesk tickets you might rename dataset1 to tickets.
The new name must be alphanumeric, with no spaces or punctuation. At the point of renaming, if the SQL query is unmodified, the name of the dataset is automatically updated in the SQL query.
Dataset buttons
Use the following buttons to create new, copy existing and delete datasets.
Query multiple datasets
Multiple datasets mode lets you leverage SQL to query data from more than one dataset at a time, and even combine datasets by using a JOIN, etc.
For example, the following query compares the number of new and solved tickets per day by combining data from two different datasets.
WITH created AS (
SELECT `count` AS NewTickets,
created_at_byDay AS TDay
FROM dataset1
ORDER BY TDay),
solved AS (
SELECT `count` AS SolvedTickets,
solved_at_byDay AS TDay
FROM dataset2
ORDER BY TDay)
SELECT TDay,
COALESCE(NewTickets, 0) AS Created,
COALESCE(SolvedTickets,0) AS Solved
FROM (
SELECT * from created
OUTER JOIN solved on solved.TDay = created.TDay
ORDER BY TDay
This builds a daily comparison of ticket creation and resolution, which you can then visualize as separate trend lines on a line graph:
