Custom Types
This feature is available with an Enterprise plan
This feature is currently only available upon request. Contact SquaredUp support about activation.
How to add a custom type
  1. In SquaredUp, browse to Settings > Advanced > Types.
  2. Click on Add custom type.
  3. Add your custom type by entering the following settings:
    1. Name:
      This name is just for you to be able to identify the type, it's not used anywhere in else SquaredUp. You can choose a name that helps you remember what this type refers to and why you created it.
    2. Type:
      Enter the value of the type property of your objects.
    3. Icon:
      Start typing to find suggestions for font awesome icons or use the link below the field to see a list of all icon names.
    4. Singular name:
      The singular form of the object type's name. This name will be displayed in SquaredUp.
    5. Plural name:
      The plural form of the object type's name. This name will be displayed in SquaredUp.
  4. Click Save.
