Custom Data Streams
How to add a custom Data Stream
Specific Entry Point Reference
What is a Data Stream?
Data streams standardize data from all the different shapes and formats your tools use into a straightforward tabular format.
While creating a tile you can tweak data streams by grouping or aggregating specific columns.
Depending on the kind of data, SquaredUp will automatically suggest how to visualize the result, for example as a table or line graph.
- Global data streams are unscoped and return information of a general nature (e.g. "Get the current number of unused hosts").
- A scoped data stream gets information relevant to the specific set objects supplied in the tile scope (e.g. "Get the current session count for these hosts").
What is a custom Data Stream?
A custom data stream is a data stream that you, as an advanced user, can write yourself.
- In SquaredUp, browse to Settings > Advanced > Data Streams.
- Click Add custom data stream.
- Add your custom data stream by entering the following settings:
- Name:
Enter a display name for your data stream.The display name is the name that you use to identify your data stream in SquaredUp. It has no technical impact and doesn't need to be referenced in the data stream's code.
- Data source:
Choose the data source this data stream is for.
After you've chosen the data source the Entry Point field displays. - Entry Point:
Specify the data stream entry point and enter the Code below.To find out which entry point to select and get code examples for the Code field, see the help below.Each data stream uses an entry point, which can either be global (unscoped) or scoped, and this determines whether the data stream uses the tile scope.
- Name:
- Click Save to save your data stream.
Generic schema reference
This section covers parameters that can be used in any entry point. For parameters that are specific to individual entry points see Specific Entry Point Reference
Global entry points can't use specific objects in the matches parameter. You can identify global entry points by their name, they have "Global", "No Scope" or "Unscoped" added to their name.
There are two possible options for the matches parameter for global entry points:
With the matches parameter you define for which objects the data stream will be shown in SquaredUp. It works like this:
When you configure a tile, you have to choose its scope. If this scope contains objects you specified here in the matches parameter, the data stream will be shown in SquaredUp under Data Streams. If the scope doesn't contain objects specified here, the data stream will be hidden.
This keeps things clean and simple since you'll only see the data stream when it's relevant for the scope you chose. As a best practice you should limit the data stream to objects that make sense for the specific use case of this data stream.
Format for matches:
//If you want to specify only one value of an object property//
"matches": {
"ObjectProperty": {
"type": "equals",
"value": "ValueOfTheObjectProperty"
//If you want to specify multiple values for an object property//
"matches": {
"ObjectProperty": {
"type": "oneOf",
"values": ["ValueOfTheObjectProperty1", "ValueOfTheObjectProperty2", "ValueOfTheObjectProperty3"]
},Example for limiting a data stream to objects:
If you are using multiple values for the object property, you can decide if you want the data stream to be visible for objects that match all of the criteria or at least one of the criteria.
Lets say you have two values you want objects to have in order for the data stream to be visible for them:
- a
SourceNameproperty with the valueAppDynamics(meaning objects that come from the AppDynamics data source) - a
typeproperty with the valueapp(meaning application objects)
If you want the data stream to be visible only for objects that match both of the criteria, your code would look like this:
"matches": {
"sourceName": {
"type": "equals",
"value": "AppDynamics"
"sourceType": {
"type": "equals",
"value": "app"
},If you want the data stream to be visible for objects that match at least one of the criteria, your code would look like this:
"matches": [
"sourceName": {
"type": "equals",
"sourceType": {
"type": "equals",
"value": "app"
]Note: Defining the matches parameter is mandatory.
Format for matches:
"matches": {
"ObjectProperty": {
"type": "equals",
"matches": {
"ObjectProperty": {
"type": "oneOf",
- a
"matches": {
"sourceName": {
"type": "equals",
"sourceType": {
"type": "equals",
"value": "app"
"matches": [
"sourceName": {
"type": "equals",
"sourceType": {
"type": "equals",
"value": "app"
]Note: If you run into errors when configuring the matches parameter, check if you're dealing with a global entry point.
Metadata can also be defined on the Columns tab when configuring data tiles. See Columns.
Optional, but recommended
The metadata parameters are used to describe columns in order to tell SquaredUp what to do with them. You can do multiple things with the metadata parameters:
- Specify how SquaredUp should interpret the columns you return and - to an extent - how their content displayed. You do this by giving each column a shape.
- Filter out or just hide columns.
Only the columns you define inmetadatawill be returned in the results. This helps you to filter out columns you don't need. If you need the content of a column but don't want to display it, you can use thevisibleparameter. - Give columns a nicely readable display name.
- Assign a specific role to columns .
The role you assign to a column tells SquaredUp the purpose of the column. For example, if you have two different columns that contain numbers, you need to assign the role
valueto the column that contains the actual value you want to use in your visualization.
If you don't specify any metadata, all columns will be returned and SquaredUp will do its best to determine which columns should be used for which purpose. If you're returning pretty simple data, for example just a string and a number, this can work fine. But if you're returning two columns with numbers it gets trickier for SquaredUp to figure out which one is the value and which one is just an ID or some other number.
Parameters:
Before you start specifying metadata, leave them empty at first and get all the raw data with your new data stream once.
In order to do this, finish creating your custom data stream without metadata and create a tile with this data stream. The Table visualization will show you all raw data.
This will give you an overview about all columns and their content and help you decide which columns you need and what their shapes and roles should be. It's also essential for getting the correct column name to reference in the name parameter.
Use this information to go back to the data stream configuration and specifying the metadata.
- Basic types, like:
boolean,date,number,string - Currency types that get displayed with two decimal values and their currency symbol (for example $23,45), like:
currency(generic currency),eur,gbp,usd - Data types, like:
bytes,kilobytes,megabytes - Time types, like:
seconds,milliseconds,timespan - The status type :
state - Utility types, like:
customUniturl(will be displayed as a link)
Tip:
If a shape is configurable, you can edit how the shape displays data in SquaredUp.
Many of the data streams in these examples can now be created easily using configurable data streams. The reference information below can also be useful editing data streams, because any data stream created using configurable data streams can be edited from Settings > Data Streams.
Data Stream for Events
Events
Code example:
"name": "customEvents",
"dataSourceConfig": {
"eventTypes": [
"APP_SERVER_RESTART",
"APPLICATION_DEPLOYMENT"
"severities": [
"INFO",
"WARN"
"rowPath": [],
"matches": {
"sourceName": {
"type": "equals",
"sourceType": {
"type": "equals",
"value": "app"
"metadata": []
}Parameters:
Data Stream for Metrics
Metrics
Code example:
"name": "kpiDatabaseAvailability",
"metric": "KPI|DB Availability",
"scaleFactor": 100
"rowPath": [],
"matches": {
"sourceName": { "type": "equals",
"sourceType": { "type": "equals",
"value": "db"
"metadata": []
}Parameters:
Example for a JQL query
This Data Stream returns a list of issues based on the given JQL query.
Tip: When you are using the blocks visualization for a tile that uses this Data Stream, completed issues will be shown as green, all other issues will be gray.
JQL query
Code example:
"name": "projectIssuesAll",
"jql": "project={{key}}&updatedDate>='{{timeframe.startTime}}'"
"rowPath": [],
"matches": {
"sourceType.0": { "type": "equals", "value": "jira project" }
"metadata": [
{ "name": "key", "displayName": "Key", "shape": "string", "role": "id" },
{ "name": "fields.summary", "displayName": "Summary", "shape": "string" },
{ "name": "fields.issuetype.name", "displayName": "Type", "shape": "string" },
{ "name": "fields.priority.name", "displayName": "Priority", "shape": "string" },
{ "name": "fields.status.name", "displayName": "Status", "shape": "string" },
{ "name": "fields.status.statusCategory.name", "displayName": "Status Category", "shape": "string", "visible": false },
{ "name": "fields.resolution.name", "displayName": "Resolution", "shape": "string" },
{ "name": "fields.project.name", "displayName": "Project", "shape": "string" },
{ "name": "fields.issuetype.subtask", "displayName": "Subtask", "shape": "boolean", "visible": false },
{ "name": "fields.creator.displayName", "displayName": "Creator", "shape": "string", "visible": false },
{ "name": "fields.reporter.displayName", "displayName": "Reporter", "shape": "string" },
{ "name": "fields.created", "displayName": "Created", "shape": "date" },
{ "name": "fields.updated", "displayName": "Updated", "shape": "date" },
{ "name": "fields.statuscategorychangedate", "displayName": "Last Status Category Change", "shape": "date", "visible": false },
{ "name": "fields.resolutiondate", "displayName": "Resolution Date", "shape": "date" },
{ "name": "url", "displayName": "Link", "shape": "url" },
{ "name": "blockState", "displayName": "Block State", "shape": "state", "visible": false },
{ "name": "blockLabel", "displayName": "Block Label", "shape": "string", "role": "label", "visible": false }
}Parameters:
name
Mandatory
The internal name of the data stream. Can be used the refer to this data stream in a tile's JSON instead of using the data stream's internal ID.
dataSourceConfig Parameters
jql
Enter the JQL query you want to use here. The query will call the /rest/api/3/search endpoint, please refer to the Atlassian Jira API documentation for details about which queries you can use: https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-issue-search/#api-rest-api-3-search-get)
matches Parameters
Format for matches:
"matches": {
"ObjectProperty": {
"type": "equals",
"matches": {
"ObjectProperty": {
"type": "oneOf",
- a
"matches": {
"sourceName": {
"type": "equals",
"sourceType": {
"type": "equals",
"value": "app"
"matches": [
"sourceName": {
"type": "equals",
"sourceType": {
"type": "equals",
"value": "app"
metadata Parameter
Parameters:
Tip:
This custom Data Stream will enable you to get different granularity or metrics than the default Cost Data Stream for AWS.
Account Cost
Code example:
"name": "account-cost",
"groupBy": [
"Type": "DIMENSION",
"Key": "SERVICE"
"metrics": [
"AmortizedCost"
"granularity": "HOURLY",
"filter": {
"Dimensions": {
"Key": "SERVICE",
"Values": [
"AWS Cost Explorer"
"rowPath": [
"ResultsByTime",
"Groups"
"matches": {
"sourceType.0": {
"type": "equals",
"value": "AWS Account"
"metadata": [
"name": "ResultsByTime.TimePeriod.Start",
"displayName": "Date",
"shape": "date"
"name": "ResultsByTime.Groups.Keys.0",
"displayName": "Service",
"role": "label",
"shape": "string"
"name": "ResultsByTime.Groups.Metrics.AmortizedCost.Amount",
"displayName": "Cost",
"role": "value",
"shape": "currency"
"name": "ResultsByTime.Groups.Metrics.AmortizedCost.Unit",
"displayName": "Currency",
"shape": "string"
"name": "ResultsByTime.Estimated",
"displayName": "Estimated",
"shape": "boolean"
}Parameters
name
Mandatory
Note: You'll find a detailed description about what each parameter does and which values you can use in the AWS API docs: https://docs.aws.amazon.com/aws-cost-management/latest/APIReference/API_GetCostAndUsage.html
matches Parameters
Format for matches:
"matches": {
"ObjectProperty": {
"type": "equals",
"matches": {
"ObjectProperty": {
"type": "oneOf",
- a
"matches": {
"sourceName": {
"type": "equals",
"sourceType": {
"type": "equals",
"value": "app"
"matches": [
"sourceName": {
"type": "equals",
"sourceType": {
"type": "equals",
"value": "app"
rowPath Parameter
Optional
SquaredUp expects data in table form, and here's where you define how the table with your return data will be structured.
The rowPath will tell SquaredUp which items you want to convert into rows.
Example:
Let's say your return data looks like this:
"generalInfo": "some info",
"results": [
"name": "object 1",
"tags": [
"tag 1",
"tag 2",
"tag 3"
"name": "object 2",
"tags": [
"tag 1",
"tag 4"
}Now it depends on what data you want to base your table on, do you want rows per object or per tag?
If you want to see which objects have which tags, your rowPath would be results, and your table would look like this:
If you want to turn each tag into a row and see to which objects they are applied, your rowPath would be results.tags, and your table would look like this:
As you can see in the example, each parameter gets turned into a column and the items of the parameter you chose as the rowPath will be turned into rows.
You might also have noticed in the example that the parameter generalInfo was included in both cases. This is because after going through all parameters on the same level as your rowPath, SquaredUp will move through all levels above the rowPath and create columns from those parameters, too. Parameters on levels below the rowPath won't be included in the table.
metadata Parameter
Parameters:
Tip:
Log Analytics Data Stream
Log Analytics Query
Code example:
"name": "customLogAnalyticsQuery",
"query": "Heartbeat | where TimeGenerated > ago(1d)",
"includeWorkspaceName": true
"rowPath": [],
"matches": {
"sourceType": {
"type": "equals",
"value": "microsoft.operationalinsights/workspaces"
"metadata": []
}Parameters
name
Mandatory
matches Parameters
Format for matches:
"matches": {
"ObjectProperty": {
"type": "equals",
"matches": {
"ObjectProperty": {
"type": "oneOf",
- a
"matches": {
"sourceName": {
"type": "equals",
"sourceType": {
"type": "equals",
"value": "app"
"matches": [
"sourceName": {
"type": "equals",
"sourceType": {
"type": "equals",
"value": "app"
metadata Parameter
Parameters:
Tip:
Custom Metrics Data Stream
Metric
Code example:
"name": "customMetric",
"metricNames": "Network Out Total"
"rowPath": ["value", "timeseries", "data"],
"matches": {
"sourceType": {
"type": "oneOf",
"values": [
"microsoft.compute/cloudservices",
"microsoft.compute/cloudservices/roles",
"microsoft.compute/virtualmachines",
"microsoft.compute/virtualmachinescalesets",
"microsoft.compute/virtualmachinescalesets/virtualmachines"
"metadata": []Parameters
name
Mandatory
rowPath Parameters
matches Parameters
Format for matches:
"matches": {
"ObjectProperty": {
"type": "equals",
"matches": {
"ObjectProperty": {
"type": "oneOf",
- a
"matches": {
"sourceName": {
"type": "equals",
"sourceType": {
"type": "equals",
"value": "app"
"matches": [
"sourceName": {
"type": "equals",
"sourceType": {
"type": "equals",
"value": "app"
metadata Parameter
Parameters:
Tip:
Example for Custom Metrics
Metrics
Code example:
"name": "cpuUser",
"metric": "system.cpu.user"
"rowPath": [],
"matches": {
"sourceType": {
"type": "equals",
"value": "datadog host"
"metadata": [
{ "name": "host", "displayName": "Host", "shape": "string" },
{ "name": "value", "displayName": "Value", "shape": "percent" },
{ "name": "timestamp", "displayName": "Timestamp", "shape": "date" }
}Parameters
name
Mandatory
metric
Mandatory
To find out which metrics are available and their exact name, you can make an API GET request to the Datadog API. Please note that some of the metrics might not be compatible with the Datadog host object. Since this Data Stream is only for Datadog host objects, only metrics that are meant for host objects can be used.
Settings for the API request:
URL: https://API_URL/api/v1/metrics?from=0
API_URL depends on the URL of your Datadog instance and will be one of the following:
- api.datadoghq.com
- api.datadoghq.eu
- api.ddog-gov.com
Headers:
DD-API-KEY: An API key you created in your Datadog instance
DD-APPLICATION-KEY: An application key you created in your Datadog instance
matches Parameters
Format for matches:
"matches": {
"ObjectProperty": {
"type": "equals",
"matches": {
"ObjectProperty": {
"type": "oneOf",
- a
"matches": {
"sourceName": {
"type": "equals",
"sourceType": {
"type": "equals",
"value": "app"
"matches": [
"sourceName": {
"type": "equals",
"sourceType": {
"type": "equals",
"value": "app"
Datadog Data Streams only work with the object type host (datadog host).
rowPath Parameters
Can be left empty.
metadata Parameters
To make sure that all your data has the proper shape you should enter the metadata like shown in the example:
"metadata": [
{ "name": "value", "displayName": "Value", "shape": "percent/bytes/milliseconds/..." //depends on the metric// },
]This ensures that the timestamp comes back as a date etc.
Parameters:
Tip:
You can use mustache parameters in your data stream. You can use them in your query as well as anywhere else in the data stream code (for example, to call an API endpoint depending on an object's name).
A mustache parameter is a dynamic value, the actual value will be inserted to replace the field in curly braces. For example, {{timeframe.start}} will insert the start time based on the timeframe configured within the tile, or {{name}} will insert the name of the object(s) in scope.
You can use properties of objects and write them in between curly braces e.g {{name}} to use them as mustache parameters. Whenever you use mustache parameters, you need to use a scope of objects that contain the property you're referencing.
For example, if objects of type "host" have a property called name, you can use {{name}}. This will resolve {{name}} to the value of the name property of the different "host" objects used in the scope.
Query Example:
"name": "customQuery",
"queryBody": {
"query": {
"query_string": {
"query": "managedEntityDisplayName:\"Microsoft Windows Server 2016 Datacenter\""
"queryParams": {}
"rowPath": [
"hits",
"hits"
"matches": "all",
"metadata": [
"name": "hits.hits._index",
"displayName": "Index"
"name": "hits.hits._source.managedEntityDisplayName",
"displayName": "Entity Name"
"name": "hits.hits._source.counter",
"displayName": "Metric"
"name": "hits.hits._source.value",
"name": "hits.hits._source.timestamp",
"shape": "date"
}Parameters:
metadata Parameter:Optional, but recommended
Parameters:
Tip:
Lucene Query Example:
"name": "luceneQuery",
"queryBody": {},
"queryParams": {
"q": "managedEntityDisplayName:\"Microsoft Windows Server 2016 Datacenter\""
"rowPath": [
"hits",
"hits"
"matches": "all",
"metadata": [
"shape": "date"
}Parameters:
Parameters:
Tip:
Custom API Call Example:
"name": "customApiCall",
"method": "POST",
"endpoint": "{{name}}/_search",
"headers": {},
"params": {},
"body": {
"query": {
"query_string": {
"rowPath": [
"hits",
"hits"
"matches": "all",
"metadata": []
}Parameters:
metadata ParameterOptional, but recommended
Parameters:
Tip:
Create BigQuery (Scoped) data stream
Code example:
"name": "exampleScopedBigQuery",
"query": "SELECT project.name, service.description FROM `<project_id>.<data_set_name>.<table_name>` WHERE project.id in ('{{sourceId}}') GROUP BY 1,2 ORDER BY 1,2;"
"rowPath": [],
"matches": {
"sourceType.0": {
"type": "oneOf",
"values": [
"GCP Project"
"metadata": [
{ "name": "name", "displayName": "Project","shape": "string", "role": "label" },
{ "name": "description", "displayName": "Service", "shape": "string" },
}Example 1: Using a Prometheus query
Prometheus Query (Global)
Code example:
"name": "prometheus_global",
"matches": "none",
"ignoreTimeFrame": true,
"query": "sum by (instance) (rate(kubedns_probe_dnsmasq_latency_ms_sum[1m])) / sum by (instance) (rate(kubedns_probe_dnsmasq_latency_ms_count[1m]))"
"rowPath": [
"results"
"metadata": []
}name
Mandatory
matches Parameters
Format for matches:
"matches": {
"ObjectProperty": {
"type": "equals",
"matches": {
"ObjectProperty": {
"type": "oneOf",
- a
"matches": {
"sourceName": {
"type": "equals",
"sourceType": {
"type": "equals",
"value": "app"
"matches": [
"sourceName": {
"type": "equals",
"sourceType": {
"type": "equals",
"value": "app"
]rowPath Parameters
Mandatory
Depends on the data returned from your query. Enter the path to the row you want to use (the row path in the code example above is results).
metadata Parameter
Parameters:
Tip:
Example 2: Get CPU usage for a selected object from a GCP cluster
Note: This Data Stream requires a Google Cloud Platform data source which has to be configured to return information from a cluster.
PromQL
Code example:
"name": "prometheuscpu",
"matches": {
"sourceType": {
"type": "equals",
"value": "compute#instance"
"query": "instance:node_cpu:rate:sum{instance=\"{{name}}\"}"
"rowPath": [
"results"
"metadata": [
}name
Mandatory
matches Parameters
Format for matches:
"matches": {
"ObjectProperty": {
"type": "equals",
"matches": {
"ObjectProperty": {
"type": "oneOf",
- a
"matches": {
"sourceName": {
"type": "equals",
"sourceType": {
"type": "equals",
"value": "app"
"matches": [
"sourceName": {
"type": "equals",
"sourceType": {
"type": "equals",
"value": "app"
rowPath Parameters
Mandatory
metadata Parameter
Parameters:
Tip:
SWQL
Code example:
Information about parameters in the script:
"name": "my-custom-swql-datastream",
"swql": "SELECT something FROM somewhere WHERE something like something"
"rowPath": ["results"],
"matches": {
"sourceType": {
"type": "equals",
"value": "SolarWinds Host"
"metadata": []
}Parameters
name
Mandatory
matches Parameters
Format for matches:
"matches": {
"ObjectProperty": {
"type": "equals",
"matches": {
"ObjectProperty": {
"type": "oneOf",
- a
"matches": {
"sourceName": {
"type": "equals",
"sourceType": {
"type": "equals",
"value": "app"
"matches": [
"sourceName": {
"type": "equals",
"sourceType": {
"type": "equals",
"value": "app"
metadata Parameter
Parameters:
Tip:
Example 1: Get Windows Event Log Entries for Given Hosts
This Data Stream uses Host objects which need to come from a different data source (for example, from the VMware vCenter data source), and performs a query to get Windows application log event messages.
Splunk Enterprise Query (Scoped)
Code example:
"name": "SplunkAppEventsForHost",
"query": "search source=\"WinEventLog:Application\" | where host = \"{{name}}\" | fields host,Message"
"matches": {
"sourceType": {
"type": "equals",
"value": "host"
"rowPath": [],
"metadata": [
{ "name": "_indextime", "displayName": "Timestamp", "shape": "date", "role": "timestamp" },
{ "name": "Message", "displayName": "Message", "shape": "string", "role": "value" }
}name
Mandatory
matches Parameters
Format for matches:
"matches": {
"ObjectProperty": {
"type": "equals",
"matches": {
"ObjectProperty": {
"type": "oneOf",
- a
"matches": {
"sourceName": {
"type": "equals",
"sourceType": {
"type": "equals",
"value": "app"
"matches": [
"sourceName": {
"type": "equals",
"sourceType": {
"type": "equals",
"value": "app"
metadata Parameter
Parameters:
Tip:
Example 2: Get Results for Saved Report
Note: This Data Stream uses the Splunk Enterprise organization object and doesn't rely on objects coming from other data sources.
Code example:
"name": "SplunkRunMySavedReport",
"query": "| savedsearch mySavedReport | fields host,Message"
"matches": {
"sourceType": { "type": "equals", "value": "Splunk Enterprise Organization" }
"rowPath": [],
"metadata": [
}name
Mandatory
matches Parameters
Format for matches:
"matches": {
"ObjectProperty": {
"type": "equals",
"matches": {
"ObjectProperty": {
"type": "oneOf",
- a
"matches": {
"sourceName": {
"type": "equals",
"sourceType": {
"type": "equals",
"value": "app"
"matches": [
"sourceName": {
"type": "equals",
"sourceType": {
"type": "equals",
"value": "app"
metadata Parameter
Parameters:
Tip:
Example 3: Get Time-Series Data for Metric
Code example:
"name": "SplunkMpoolUsedMetric",
"query": "| mstats avg(\"spl.mlog.mpool.used\") WHERE \"index\"=\"_metrics\" span=60s chart=true"
"matches": {
"rowPath": [],
"metadata": [
{ "name": "_time", "displayName": "Timestamp", "shape": "date", "role": "timestamp" },
{ "name": "avg(spl.mlog.mpool.used)", "displayName": "Value", "shape": "number", "role": "value" }
}name
Mandatory
matches Parameters
Format for matches:
"matches": {
"ObjectProperty": {
"type": "equals",
"matches": {
"ObjectProperty": {
"type": "oneOf",
- a
"matches": {
"sourceName": {
"type": "equals",
"sourceType": {
"type": "equals",
"value": "app"
"matches": [
"sourceName": {
"type": "equals",
"sourceType": {
"type": "equals",
"value": "app"
metadata Parameter
Parameters:
Tip:
Creating a custom data stream allows you to created a scoped data stream, i.e. a data stream that makes use of objects in the scope.
HTTP Request (scoped)
Code example:
"name": "scope example",
"matches": "all",
"endpointPath": "post",
"httpMethod": "post",
"idSeparator": "], [",
"headers": [
"key": "header1",
"value": "header1Val"
"key": "sourceIds",
"value": "[{{sourceIds}}]"
"expandInnerObjects": true
"rowPath": []
}You should set the matches statement so that your custom data stream appears when you select the appropriate object types in the tile editor. You can use additional mustache constructs when using the scoped entry point: targetNodes, sourceId, sourceIds in selected dataSourceConfig parameters as shown below. The separator inserted between sourceId values in the sourceIds replacement string can be changed by setting idSeparator in dataSourceConfig.
Parameters
Mandatory
Format for matches:
"matches": {
"ObjectProperty": {
"type": "equals",
"matches": {
"ObjectProperty": {
"type": "oneOf",
- a
"matches": {
"sourceName": {
"type": "equals",
"sourceType": {
"type": "equals",
"value": "app"
"matches": [
"sourceName": {
"type": "equals",
"sourceType": {
"type": "equals",
"value": "app"
Optional
The rowpath (Path to data) will tell SquaredUp which items you want to convert into rows.
Example:
"results": [
"name": "object 1",
"tags": [
"tag 1",
"tag 2",
"tag 3"
"name": "object 2",
"tags": [
"tag 1",
"tag 4"
If you want to see which objects have which tags, your rowpath would be results, and your table would look like this:
If you want to turn each tag into a row and see to which objects they are applied, your rowpath would be results.tags, and your table would look like this:
As you can see in the example, each parameter gets turned into a column and the items of the parameter you chose as the rowpath will be turned into rows.
Parameters:
Tip:
